Does anyone know if the rear skid from an RX1 will fit into an SRX or is there a lot of modification to do?
question 2- If i install a 1.25 inch track and stud it do I have to change the drivers and if so will I have to gear and to what gear
motodave289
Rx-1 top shaft is 1" narrower, just add 1/2'' spacers on each side. Everything else is the same. 1 1/4'' track with studs would go with 8 tooth drivers and cooler protectors & regear if needed. Without studs could use 9 tooth, but with studs getting pretty close to front cooler.
Thanks MOTODAVE, are all other mounting locations the same or will I have to drill new holes?
motodave289
All locations the same, just need to shim middle/top shaft.
Thanks again Motodave, have you tried this and how does it work?
xsivhp
That shaft you need is under $50 - I'd just get the right shaft and be done with it. my 2 cents ...
