I put a 2 inch powermadd riser on my 2004 viper ER.. AM I going to turn the steering and suddenly accelerate into a FLIPPIN TREE??????? DO I NEED to extend any throttle cables???? it APPEARS to be OK,,, But,, I would rather be safe than sorry>> Thanks........ Gary Oles nosboy
shavedheadedyamaha
it should be ok i have a 2inch powermade on my srx and its fine just put it on the stand and start it... crank both ways and at fullest points tug the cable to see if there is still little play or for idel ramping
TimeBomb
i have a 2" powermadd on my 02 viper, been fine for 6,000 miles. you shouldn't have a single problem
triple
Is 2" the most you can go with the stock cables? I have a 2" riser for my srx but might go a little higher. What's everyone do, buy MM cables for the tall(er) risers?
mdbauer62
nosboy said:I put a 2 inch powermadd riser on my 2004 viper ER.. AM I going to turn the steering and suddenly accelerate into a FLIPPIN TREE??????? DO I NEED to extend any throttle cables???? it APPEARS to be OK,,, But,, I would rather be safe than sorry>> Thanks........ Gary Oles nosboy
It seems that the ER's have tighter cables than the other Vipers. If you want to be safe and have room to spare, you can use these 2" longer cables from the Mountain Viper:
1. Throttle Cable: 8EN-26311-00-00
2. Oil Pump Cable: 8EN-26320-00-00
3. Parking Brake Cable: 8EN-26351-00-00
4. Brake Hose: 8EN-25872-00-00
All add up to about $80-90.00
I have them ordered, and will post the results. I went to 3.5" on a 02 Viper ER and no amount of re-routing was going to fix mine.
You may have to re-route the cables and slide your brake in a bit to help.
ExpertXViper
I had a 2inch on my Viper for one season with no issues. This year Ill be running a 4in. FLY riser on top of that 2in. riser. For that high of a riase I extended all the cables and wires(hand warmers, killswitch, etc)
The 2004 Viper is unique because it has the 2 into 1 cable. I want to go with 4 inch risers and not sure what to do. I think the 2004 Viper MTN has same cable but 2" longer, not sure if long enough. I'm ready to do this ASAP.
Thumper1
TimKarp said:The 2004 Viper is unique because it has the 2 into 1 cable. I want to go with 4 inch risers and not sure what to do. I think the 2004 Viper MTN has same cable but 2" longer, not sure if long enough. I'm ready to do this ASAP.
what is 2 into 1?
Truckkid42
i have a 3 inch on my viper without any problems what so ever, and i didn't even have to re route anything.
I also have a brand new 3 inch powermadd im willing to part with if anyone wants it.
heres a thread about the max length on handlebar risers for a viper:
http://www.totallyamaha.net/forums/showthread.php?t=27347
I'm puttin a 5" on my ER-04
