Trailing arm spindle bushings
tomseal6
Brevort, MI
Guys,
My 02 SRX with 7,100 miles
If the trailing arm spindle bushings are shot, would it cause the entire ski to tilt slighty inwards.
My entie left ski is leaning slightly to the right
My handle bar is straight.
Scott
This just happened when I put new carbides on it.
I took off some 10 inch duallys to install some regular 6 inch carbides along with bergsroms ski saver and shim kit.
7100 miles and there is not a dent or scratch on this sled. Let me know if you still think its bent
Ok I rule out the bushings.
That was the trailing arm I replaced 700 miles ago and it came with brand new bushings
I only replaced the arm because it had a 2 inch scratch in the paint
LOL S.X. was laughing his butt off at that at his place where we did it. He couldnt get over how I bought a new one over a small scratch
OK!!!!!
My other side is like that too. Is there some adjustment I can do with the radius rods and bring them out 1 full turn??
SERIOUSLY??? THATS IT??
YOU GUYS ARE OK.
Thank you
It was like that all along. I just didnt notice it as much with the Dually carbides on.
I'm the same way tom, picky!!!!! :)
Yup like Old Thumper said they can be adjusted, pull the bolt outa the RR
on the sled side(under the hood,the bulk head)drop it down break the jam
nut and turn the ball joint the way you need to..
spec tom is from center hole to center hole of the RR..
upper- 460.2mm(18.118in)
lowwe-458.7mm(18.059in)
