lilracer
Just wondering everyone's opinion and experience with different headlight bulbs for a 2000 SRX ? I was thinking of either the blue tinted or the Xenon bulbs. Also what watt ? Any advise would be greatly appreciated ! Thanks in advance.have you done a search on this subject...a few have tried different, things...I run bright lites from cb performance...a lot better than stock...lilracer said:Just wondering everyone's opinion and experience with different headlight bulbs for a 2000 SRX ? I was thinking of either the blue tinted or the Xenon bulbs. Also what watt ? Any advise would be greatly appreciated ! Thanks in advance.
RIVERRUNNER
I use sylvaina silver star bought from a automotive store, they seem to be alot better then stock. But, use the same wattage as your stock bulb or you might have heat issues causing melting. There is a a lot of reading if you search..........
lilracer
thanks guys i appreciate the quick reply !
moss
RIVERRUNNER said:I use sylvaina silver star bought from a automotive store, they seem to be alot better then stock. But, use the same wattage as your stock bulb or you might have heat issues causing melting. There is a a lot of reading if you search..........
I do the same, and I found a red LED for my Taillight at Ca tire
moss said:I do the same, and I found a red LED for my Taillight at Ca tire
the only thing with the leds is no heat...no melting of the snow dust on the rear lens...a lot of my buds say they have a hard time seeing my light in the day too...a clear lense will fix that, not the melting...did that, went back to stock...my 2c safety is more important than looks
i like the blue tint bulbs personally. gives much better contrast at night and the light does not blind you when it reflects off of the snow. i find silverstars in my p/u are brighter but i get a lot more snow reflection from them over the blue tint bulbs i had in there before.
Roost 'Er
Running zenons here but personally, with lots of experience in my car without a HID set up PIAA's are by FAR the best ive run them all from the off road zeonons, to silverstars to nighthawks... PIAA's are the best they are pricey but worth it...
2000 srx is H4 bulb
2000 srx is H4 bulb
moss
theblues said:the only thing with the leds is no heat...no melting of the snow dust on the rear lens...a lot of my buds say they have a hard time seeing my light in the day too...a clear lense will fix that, not the melting...did that, went back to stock...my 2c safety is more important than looks
Hmmm good points, will keep it in mind, I'll keep the stock around incase I run into the same thing.
