Power Valve Adjusment!
Viper-Rules!
Kitchener,ON Canada
How do most of you guys adjust your power valves on your viper? I looked in the tech section and it stated to loosen the two screws on the valve assembly and to turn the adjustors clock wise or counter clockwise to increase or decrease the gap. It is hard to see from the pic what that 3.0mm dimension gap is applying to. Not too sure what I'm suppose to be measuring inside of there. I just had to replace a broken cable and now what to re-syc the three valves.
Steve
