viper TORS
johnnyc
wallingford, ct USA
Anyone know the proceedure to troubleshoot the viper tors system? Sled only runs good when the system is by-passed. throttle free-play is adjusted to specs. Trying to figure out which switch is bad, throttle lever or carb. Thanks.
Did this just start only after you had the carbs off or was it there before & have not removed the cables or carbs off...
Viper TORS
Problem was there from late last season, was intermitten at first, but is now constant.
EDIT: Figured it out, Used continuity tester to test switches.Carb switch failed test, removed micro-switch at carbs, disassembled switch and cleaned contacts, works perfectly now.
Good for you...now :letitsnow
