Bender pipes on 600. SET UP with heel clickers and roller secondary
Nicko
Argentino Loco
Mound, Minnesota
I have the chance to get a set of benders for my 600 with hell clickers and a roller secondary...Any inputs guys...TURK...?
I was running 89 L weights and a 49/41 helix....Should I leave the 89's or use the heel clickers.....How about the roller (helix).....Shoot me some advice guys....
Nick
If you use the hc,s your gonna need a real shallow helix; about a 44/38ish. The 89L,s with the helix you have would be real easy to dial in & work great.
Ok that is what I'll do..Thanks turk....So good pipes and with those weights and roller I will be a lot better than the center dumps ha ?
Jets ? Pilots ? Needles ?
What kind of helix and springs should I be looking, I guess I was running a green sec and g/y/g it was the stock primary spring...?
The roller is a maxx peformance i think
So I'm trying to get a hole set up...
Thanks again sir...
Nick
I can,t comment on your roller; never used that one.49/41 non roller would work awesome tho with 89L,s.
Onem more ? please
Ok sounds good. One more if you don't mind
I was running the PI center dumps with the 89's and the 49/41 yamaha helix, like I said stock primary and green sec. my RPM where around 8150.
The bender run at 8800/8900 right...? So if I use the same set up what would raise the rpm's...I'm missing something right...?
Nick
Run the Benders at 83-8600 rpm. I set up 2 600,s & they like those rpm,s. 8800 is way too high.
You could try calling Justin Fuller at Full Power Performance. He was the main R&D guy at Bender Racing before he went into business himself. He knows how to tune anything Yamaha. He gave me tips and pointed me in the right direction, got my 600 screaming...
716-699-6299
Thank you will do that also. I hope he is close to what Turk said because I'm following his advice first...since he set me up before and did great...But I will keep all my options open...Thanks guys..
Nick
