slp piped viper clutch question
krazyzx9
MN
I am in the process of replacing the clutch weights. I cannot figure out which are the heavier 17.2 gram rivets. I need to put 13.9 in both holes. I am not sure which is which in relation to the inner or outer hole. closer to the pin or tip. Which one is the inner or outer. THanks for you help....Blake
I figured it out. Did not know about the diagram. I thought it just said which weights, not location. Does not matter. Its running GOOD!
