xsivhp
Has anyone tried running without this cross brace?
you have a jack in it, you wont need it anyway. why do you want to remove it though?
nailsandrails
xsivhp
BTV - I was wondering if having the jack in there would be enough. Thanks!
snowdust - the stock ones don't hit, but I'd like to run 7 1/8 rear wheels. How big of wheels are you running? Because I was thinking of moving it like you did. How far di you move it?
thanks!
thanks!
xsivhp
also what offset axle are you running and what size wheels?
thanks!!
thanks!!
nailsandrails
I don't know what the exact measurement is where I moved it off hand. I just made sure there was plenty of material to drill the new hole. I am running 8in rears. I can't seem to remember the offset axel brand right now. I got it from Rich on this site. I have had aheck of a time getting enough track adjustment, but I can't blame it all on the axel and wheels. Some of the mounting points were not quite right originally.
xsivhp
If that's the same offset axle kit I got from him in Aug of 06 I think it's suppose to run 6-3/8 wheels in the inside and 8" wheels on the outside. That may be why your track is too tight?
This is the onse I had:
Thanks for the pics - and the input too!
xs
xs
when i ran the 8in kit on my viper, i had to machine the blocks on the hpe axle kit so it would let the wheels go ahead about 1/4 so i could get the track loose enough. it worked good but i had to mount that shaft on the lower front bolt instead of the upper.
i also cut the bottom of the slide block 10mm shorter. loosens the sled up front to back. .
nailsandrails
Well that's refreshing. I have that same offset axle and also had to modify it to allow for enough track adj. I was not real happy that I had to do this after what I paid for that axle.
BETHEVIPER - What "Slide Block" are you referring to?
nailsandrails
XSIVHP - I do have the 8in outside and 6 3/8 inside. Without making some changes to that aftermarket axle it is fiddle tight. I have a long thread documenting my frustration if you do a search.
xsivhp
I noticed that even with the stock M10 setup there is only about .125" clearance - so I can see where you may be having troubles. That sucks. I'll keep you posted; I'm ordering parts today.
xs
xs
xsivhp
update - I just talked to fast and they, like BTV, stated that with the Jack you do not need the cross support. woo hoo!!
xsivhp
Got the whee kit in .... what do you think?
Put bolts & nuts inplace of the shaft...don't leave them empty...
xsivhp
roger that - I think I'm just going to run std. size wheels - these hang below the slide about 1/2" - seem like too much to you?
xs
xs
I would say so...that would put to much pressure on the front of the slides & wear them out sooner, you would think...would you have team fast number...or can you give me the front shock preload settings...thnks
