Concept Carbon
Ok Im currently running 8dn-20 with 4.5 in both holes, www prime and green secondayr with 51/43 and 70 deg
engagement is about 4000rpm
but it revs up to 8600 and climbs to 8750
I have srx pipes and cdi in my vipe rso im shooting for 81-8200 and climb to 84-8500
Im goni gto be swappin gthe whieght out for 8bu-oo but customs is being real slow and dont have them yet so for the meen time what should I do.
all i have for ect.. clutch stuff is red second spring stock viper helix and wht/yel/wht sping and 8ek wheghts
would seting my secondary spring to 60 deg rap help.
any thing helps thanks.
Turk
TY TECH ADVISER
- May 2, 2003
Drop secondary wrap to 60. Get some new 4.5 rivets & before you peen them over put a 1 gram washer under the rivet.make sure the washer does not interfere with the roller cam arm making contact.This should get you a lot closer. If that doesn,t work it,s time for a steeper helix.
mrviper700
VIP Lifetime Member
or just simply put button head bolts and nuts in the weights instead of rivets
Concept Carbon
thanks for the help guys, sucks the border is taking so long. Il give it a try. IL probabaly end up getting my 8bus tommorrow after all this
seca
hey C.C. want to sell your 8dn-20's? let me know.
Concept Carbon
i PROBABLY WILL BE SELLING THEM IN A WEEK OR 2.
Set the wrap too 60deg and its alot better, not perfect but better shifts at 8300 and clibs to 8550
Roost 'Er
hey carbon any luck selling the lude?...
thanks again for the hood...
Skidooslayer687
lol so how many hamsters are under that hood??? hahahaha just jokin
