02 viper fuel issue....?
viperific
2 harbors
so last day of the year i was out riding and ended up getting bad gas and melted down in one cylinder 0n my 02 viper, i put a new jug, piston and rings on and changed out the old gas.. now in the different cylinder (the middle one) its not getting fuel with the choke off, when the choke is on it seem to switch to another cylinder...? im getting good spark on all three and if i rev the motor up it seems to pick up and get get fuel to all three cylinders...
any ideas why it wont get fuel at idle to all three cylinders?
thanks viperific!!! :winterrul
Millinocket Rocket said:
Have you cleaned the carbs and the jets out real good? Sounds like plugged/ dirty pilots.
Agreed, dirty pilot jets. I usually have to use a small piece of wire to get them clean, haven't ever had air or cleaner do the job very well. Make sure you can see light through all of them.
