Need Help Please
mm700sleder
New Hampshire
I was just wondering it anyone knew the length of the stock front shocks off a 2001 mountain max. I am looking to buy a set of ohlins. The ohlins have a length of 343mm and a bore of 103mm. Will these work on my sled. Some help me out
I'll try to remember to measure my Ohlin's tonite. I can tell you that it takes a special bracket to extend to mounting holes. Short track front Ohlin's will not work because of wider ski stance.
They work fine (I have short track front Ohlins on my MM). Only downside is that the shock is not in maximum extension anytime, since as WANNA4STROKE says.The narrower ski stance on the MM prevents it from fully extend. They work perfect even though on the MM. I have had mine on for 2 seasons and they are super!!!
//Rob
