progold
Hey guys noticed that my viper was ratcheting quite bad off the launch,was taking my nephew`s f7 but had to tighten my track then could`nt keep up with him so my question is how difficult of a job is it to install anti ratchet drivers on a 02 viper?
redsnake3
its very easy to do, worst part is that you need access to a press to get them on.
bluewho
The kimpex ones are easy... remove outer wheels slide theres right up to the inside stock drivers than put the outer ones back on.Just remember they have to be timed and take some plastic off on a lath or the drivers will hit the front shaft.
richierich
easy if you have a press.....or take them to a shop.you'll also need all windows open on your track.which the stock track is not.
bluewho
The outers will come off with a heat gun and putting the axle it a vice up right and pulling down with a 2 by fer.The inners fergitt it.
xt700
- Jan 27, 2006
not very hard to do with a press, i just did it 2 weeks ago.. My only regrete is not going to 8 tooth insted of 9. i didnt know you had to take so much off the teeth of for the track to actually turn! anyway my advice is go 8 and that way you get the extra clearance if you ever wante to stud a taller lug track
Pat
Pat
progold
Bluewho What Do You Mean That They Have To Be Timmed Dont Want To Sound Dumb But Really Want To Do This Mod And Want To Get All The Info That I Need To Do The Job Right And Thanks To Everyone Who Added Their Input.
