Viper running - What do you guys think?
..SNAKEBIT..
NE IOWA
just got my Viper running and it idles and runs part throttle fine, but when I hold it open it starts to bog and I need to try a feather it to get it to open up. carbs are set same as last year, I replaced the sec clutch bushing (boy was it loose) also noticed when taking out the set-up from out west the roller bushings were shot and 1 weight was worn off the side?
2002 viper CPR pipes
cleaned carbs ( they looked real good )
8dn-10 weights (2 rivets?) stock spring 15.6 rollers
50/40 helix with green spring 80'
