Stock Viper in grass drags...
snowprophet1
Waterford, Pa.
My little brother has a viper (all stock except for a differnt helix and studs). Anybody know what you can safely jet down to for grass drags? Any other tips on suspension setups? He already chained his front shocks down a little. Thanks!
135 mains, .9 airs, lift needles one clip,50 pilots, 2-2 1/2 turns on fuel screws, engage at 5000-5500, pull front end down till the radius rods are below level. pull front limiter all the way up to the ends of the stud, back off rear shock spring (first)1 in. set fra to soft. with all this done set on sled and track should set off the ground in the rear just a bit. take off your carbides, use atleast 192 chisles. try it out a bit and adjust from there. ajust sled so you sit up to start. if the sled comes up more than 18in off the ground at the start then set less transfer. hope this helps.
