I found that on my 99 srx the heated grips were all or nothing.
it mostly burns my thumb.
I had to unhook them I could not get them to shut off.
Anyone else have this problem?
700triple
My vmax and my brother srx have the same problem. Only the thumb heat. One grip is cracked on each of our sled. Check for that. I am supposed to get a new one this week. I will keep you up to date on that.
yamaholic22
The handwarmers are wired in parallel with the thumb so if the handwarmers are out the thumb gets all the power and will burn your thumb off. Get the handgrip warmers replaced if they are bad and you will be back in good shape.
700triple
Thanks yamaholic22
