MICHAELSF150
Do transfer rods make a big difference to the traction of the pro action sleds? My traction sucks. I have a 1" lug and 96 studs down the middle. what else can i do? The sled is a 600 twin vmax sx
JohnnyQuest
Adjustable rods make a HUGE improvement!!!!! i would STRONGLY suggest getting s set, you won't be dissapointed
i have a set that i dont use .i have gone to the airwave
moss
JohnnyQuest said:Adjustable rods make a HUGE improvement!!!!! i would STRONGLY suggest getting s set, you won't be dissapointed
Do they help with track spin?
JohnnyQuest
They help you hook up WAY better!
moss
Can they be put in with the skid on the sled? or do you have to drop the skid?
nfrantz007
Skid has to be dropped to pull top idler wheel off. I just replaced mine this past weekend. Not that big of a deal.
I unfortunately replaced them with stock ones... Sounds like I will regret that decision!
nfrantz007 said:Skid has to be dropped to pull top idler wheel off. I just replaced mine this past weekend. Not that big of a deal.
Did you took the whole skid or just drop the rear. Nick
I got a set and I'm lazy to do it with 12" of snow on the ground
nfrantz007
just have to drop the rear... 6 bolts. I had to use a puller to get the wheel off the bearing.
hat do you mean 6 bolts....2 right...?
Yama49601
s fortuna said:i have a set that i dont use .i have gone to the airwave
PM sent...
JohnnyQuest
some older vmax's have 3 bolts per side, most have just the 1 per side. It's a SUPER easy project, takes maybe an hour or so if you have ANY mechanical ability
nfrantz007
yeah sorry... I have a 96 vmax... 3 on each side
I did mine in about a half an hour but I'm getting VERY good at taking out the pro action lol.
Post some tricks or ideas on taking it out easy...Did you took the hole thing or just the rear
Nick
Nick
tedgoesfast
they make a big differance i bought benders it adjusts weight transfer and coupling best money i spent
Nicko said:Post some tricks or ideas on taking it out easy...Did you took the hole thing or just the rear
Nick
I dropped just the rear (four bolts on 97 and newer) Used a puller to get the wheels off. you can get by with a rubber mallet but you better be careful. remove the old rods, install the new and put everything back in reverse order. when you go to bolt your rear skid back in leave the bolts at the bottom of the transfer rods really loose, bolt up the middle skid bolts first and then the back. I hang my sled from the rafters in my garage and use an automotive floor jack under the rear skid to help re install it.
Got it...THANKS
Nick
Nick
your welcome... If you run into any snags installing the tranfer rods just shoot me a PM and I can help.... I check TY religiously throughout the day so I should be able to respond quickly.lol
