Bender Repack
Yamanewf
Paradise,Newfoundland
When you look in a Bender can should you be able to see the packing? Where is it? When I look in mine all I see is 3 little pipes and a diffuser plate.
The packing is about 1/2 thick and goes around the diameter of the body. You would not see it from the bottom because there is a holed piece of metal covering it. If you are worried that the packing is burnt out, drill the rivets out around the top, pull the top off, then you will be able to see the condition of the packing. Just put the top back on, install new rivets and you are set to go.
