yamahaulinass
what are the three outside air jet setings (turns out)
there is no adjustable settings for the airjet other then changing out the jet itself, they are screwed in tight in the rear bell of the carb, the only screws adjustable are the fuel screws, located on the bottom front of the carbs, you need to have the rack upside down to do them unless you have remote adjusters. these control fuel flow so in is leaner, out is richer.
