anyone using the supertorquer hcx rigid secondary clutch??
overpowered srx
NORTHERN, IL
i have a 2001 srx 700 with a few mods and was thinking of using this clutch are they good or no if anyone is using it could u give me some feedback on it
thanks mike
rigid secondary
I dont have the actual secondary but I have the kit you used to be able to buy and installed it on my stock clutch. It has great backshifting. I found the top end to be very consistent in run after run (1-2kms difference), supposedly due to better belt squeeze and less slippage. I was advised to run a straight 42 helix and i rev 8600 at 60 degrees. I am going to install a primary kit this year. Does any have the 2 speed weights from heel clickers? how are they?
