crawln600
I decided not to buy a kit, so this is where im at with it now. Sled is a Stock 1995 V-max with 96 studs. And a Zr skid.
8ca's with 2.4g's in each hole
Unsure of spring, its not stock or a yamaha. Clutch engages at 4100 rpms.
Micro 50-42 Helix
Yammy green spring at 70 degree wrap. Its in 1 and 6, im going to ride it next week hopefully to see how it acts.
Im going to buy the correct yamaha spring for the primary. Should i change anything else. Also how much difference will the 50-42 helix be from say a 51-43 or a 50-44?? or is not enough to lose sleep over.
Micro 50-42 Helix
Talk to Turk he will get you going in the right direction. i clutched my 96 600 and that thing was quick...
crawln600
that is pretty close to the setup ive seen him recommend before. just looking for some input on it.
