bbender785
... same steps apply to my little brother 600?
i also wondered if any clutching or jetting changes are required/recommended. thanks.
600 triple , yes...stock jetting is fine
yamahagirl
Check your hyfax ...
clutching??
What about mine mr. sled? I need to clutch after the head gasket mod??
yes a clutch kit is a must ...it will overrev like crazy.....8ab w/2.4g in both holes, gsg spring, 48/43 with green sec spring
srxbully
how do you cut the gaskets down 10.000 or so forth?is it just removing one or two of the gaskets?
remove one of the outers...go to the tech pages it tells all about it in there.
