Ultimax belt with shim kit? MM
norwegian
Well-known member
norway
I bought the ultimax 3 belt which is 1/4 longer than the stock belt, with shim kit to get it to ride on top of the secondary. I don't understand where I should put the shims? Putting them between the sheaves would only increase the gap between them making it drop even lower down in the secondary?
Do I fully remove the 3 screws behind on the secondary when using the shims?
