Need to find the web site for Super Torquer
Howden ,Manitoba,Canada
Had my clutch apart this evening,checking everything out.Wanted to remove the three 5.0x0.8x12.0 mm stainless steel button head bolts to add some washers.One came off,the other two the allan wrench spun and wrecked the heads now,so I canted remove them .I put the other one back on and will leave everything that way for now.How can I remove them friggin bolts now and does someone have the web site address if there is one for Super Torquer Systems Inc in Litle Falls,MN.I need to order new bolts and extras plus extra washers for the heel.If I can get news parts,I will just use a small vise grip and remove them.
You can buy the same size bolts at C-Tire. Take a weight with u & match em up. I never ever had a prob with the bolt in the heel unless loctited; too small allen or too tight
since were on the topic lol.... should you loctite the bolts into the weights... I know the instructions tell you to but I never have, Just put them good and tight and I've never had an issue with them backing themselves out. Just wondering cuz i'm going to have the primary apart soon and just wanted to have some input on the loctite??? any suggestions????
i never used it & never had bolts come out....even with hh,s hc,s & supertips!
