VIPERDOUG
I need help. The battery is fully charged, but all it does when I turn the key is make a clicking noise. Is the starter bad or a bad relay..... Any help on this matter would be much appreciated.......
p.s. it's a 2002 viper er
Thanks in advance, Doug
VIPERDOUG
re:electric starter issues......
anybody have any suggestions???????
You can check the power up to the relay and see, then check after wards.
I would then just jump the relay and see if the starter works,, if it does, thats your problem
Also a load test on the battery would tell you if its good. A dead or old battery may not take a charge. A volt meter can still show over 12 volts on a battery with no cranking amps. Have you tried another battery?
real easy to see how a battery is with a simple volt meter on it and then crank it, if its dropping under 11 volts when the start is engaged, its junk, bad cell.
