overheating 97 700 triple sx
97 vmax 700
alaska
hi gang ,well 2nd time out tihs yr we finally got to the highgrounds,great snow great day till i started to get hot shut her down right away no harm there,but,
took off the cap and with motor running i notice no circulation in the cooling system,so io got towed home by nun the lees than an old tundra HAHA
anyhow i tjhink its the waterpump
what all is involved in chhanging the pump and is there anything else i may check or be aware of before i tear into this thing
also the coolant resevoir is full
thank you for your time and all the insight you guys gave in the past :o|
also ive been getting alil track chatterduring fast takeoffs?
Is the belt driving the pump okay? Might not be as serious as pump failure. Maybe just a worn or lose belt.
No belt on a tripple.....gear driven off the crank
Better hope you have a bad impeller, because if its the drive, the oil pump is on the other side of the case, running out of water is less costly than running out of oil. Pretty sure you are going to have to remove the engine to check this out. It sure would be easier to remove the pump cover, then you could see if the impeller is trashed or spinning freely on the shaft. Seems to me that this impeller is metal and held on by a bolt, but go online to find the microfische and it should give you a better idea. Good luck.
