2000 sxr 700
cedar springs michigan
help i just replaced my track with 1 1/4 track also installed 8tooth drivers . if i used the stock gears will it be to low of a ratio . stock i had 22 tooth on the top and 39 tooth on the bottom . i was told to use 24 on the top and 38 0n the bottom to get back to stock . thanks :letitsnow
