SX-R suspension
jplax156
hilton
I have a 2002 sx600r, how far should the bumper be off the ground with the stock suspension.
Also I believe my chaincase is leaking, i am getting a oil leak underneath the front of the running board almost right near the corner of the heat exchanger. Is it easy to change the seal on the chaincase.
Under the tech sectin of this site there is a link to a swedish site that has setup specs for your sled. The Chaincase has a reusable rubber seal and its isn't too hard to pull the exhaust "suitcase" and pull the cover to check.
