Need clutch puller help ASAP
Get one from a dealer...a large amount of force is on the bolt when using it to pop a clutch...don't go cheap, cause your gonna hurt yourself...
Do you know a part number for a genuine Yamaha clutch puller? Or better yet a site that sells them?
Yeah but is it a genuine Yamaha puller? I don't even know if they make one but the one my friend bought I ruined when trying to pull my clutch off with it (it was cheap garbage). Well I don't know if it was totally ruined but it wouldn't pull my clutch off. It bent and I never did get it off...
i use kimpex pullers personally, done me great and i must have had pulled a clutch atleast 100 times with it. if it seems that it isnt coming off, just take out the puller, pump the cavity full of grease, then install the puller, makes a little mess but comes off with no problems. ive only ever had to use the grease once and that was on a rev.
Anyone used a Parts Unlimited puller? That's what my dealer has and some of the vendors here too. If I would've unknowingly went to the dealer and bought myself a clutch puller, that's what I would've probably gotten.
You know I think I'm just going to get the parts unlimited puller. I'm going to try it and see what happens. I'll use the grease method and see how well the puller holds up, I'll let ya know what happens...good or bad lol
puller
I have the EPI and it seems to be holding up extrememly well. I was told when I bought it was one of the strongest.
