XT_WFO
Went over to help my Bother N law change out his track, Its the Breaking for the drive axle Speedo Side. On Ronnies website (Yamaha Microfische its Part # BEARING (8CJ) 93306-20589-00 (Ref #7) )
Curious to see if anyone Might have got from a local Bearing Company or is this gonna be a Yamaha direct order part.
take it to NAPA. They will be able to cross it and get it for you for cheap.
nitris223
If it is the bottom drive shaft bearing on the clutch side. They are available. 25mm not 25.4 mm. Should slip on snug. ( ***205-100N 2RS) . That is the numbers that was on the side of the bearing. I ordered one form a recreation supply company. $26 cdn or $65 at the dealer. Put a grease nipple in the speedo housing at a angle that you can get at with the clutch on. Grease it every so often. Helps drive the moisture out that gets in there. Red loctite the nipple in place. You have to put it on the step shoulder or it will interfear with the bearing. I went right on the edge at a angle.
nitris223
I just noticed that the mods must have bleeped out some of the part number. It starts with AS and one more S . It's part of the part number , not trying to swear.
