Hey guys I was checking my power valves and not shure wich way those the angle on the power valve go? I think my power valves are on upside down. Those the angle on the valve go up or down?
Search tool=great tool
long flat side up & bevelled side down...do a search & you will see many threads on how to clean & adjust them...cheers
theblues said:long flat side up & bevelled side down...do a search & you will see many threads on how to clean & adjust them...cheers
Well well well what do you know my power valves wher instaled the wrong way. Know my sled revs 8700rpm's which is alittle high. But big difference and also top speed is better at 110mph.
SRX7
Slide them in this way the bevelled side you can't see it's facing down.Bullit01 said:Well well well what do you know my power valves wher instaled the wrong way. Know my sled revs 8700rpm's which is alittle high. But big difference and also top speed is better at 110mph.
