GPX 338 Rpm
SR643
MI
Does anyone know what rpm the stock 338 gpx should run at.
Thunder Jet RPM
What would be the RPM for the 1945-75 Thunder Jet with the 338? Only reason I ask is the difference in exhaust. Thanks
How about a 433? i remember mine with the stock carbs and clutching would run up to 8600,now i have 75 heads and cylinders mildly cleaned up with the combustion chamber mod ,40 over wiesco's,hewtech cdi and a set of 38 mm mik's.i'm thinking it should be in the 8400 to 8600 rpm? it will be run on the ovals in the superstock class
