transfer rod spacer dilemma
darkangel
MN.
Ok...got the last of my parts from PP yesterday. Will be starting tomorrow to long travel both my 97 SX & 98 SRX. When I spoke with PP I told them exactly what I had for sleds. The spacers they sent for the transfer rods are 7.5mm. Went the local dealer for lubes and oils and mentioned what I was doing and they said I needed the 2.5mm for the bottom??
Searched on TY and found a number of posts in which some say use the "thin" ones or the "viper" ones and yet some say the 2.5mm and some say the 7.5mm.
Not a part number listed in any thread or a definitive answer.
Anyone know for sure which ones(and please don't say the thin ones!..hahah) to use on these sleds. I now have the 2.5mm and 7.5mm...HELP :o|
I used the thin ones on the bottom, that came with the 03' Viper suspension and the thin ones that came with the Bender transfer rods on the top. I'm also using the upper part of the transfer rods that came with the Viper suspension [not sure if they are the same as the stock 98' SRX or not] with my Bender adjustable lowers. Without using the thin ones [not sure the size], I could not get the gap correct.
