In the middle of changing track and following instructions here. I cant remove the chaincase, do I need to remove entire parking brake assy and is there a trick to it. Does the rotor come with the case?
saskattakman
take the capiper off the chaincase and tie it out of the way then disconnect the park brake cable from the park brake.....take out the 3 bolts that hold the chaincase to tunnel....yes the rotor will come with but watch for the keyway that holds the rotor onto shaft....should be good to go any other q'?s just post em
got that all done but cant seem to get the case out. should i just tug harder?
Ding
Darn Tootin'
Sometime the rotor slops to the side and binds on the jackshaft. With your 3rd arm . . . reach up and rock the rotor a bit while you pull on the chaincase. It is kinda of by feel but once you get the hang of it, it should pop right off. Watch the knuckles or wear mechanics gloves.
Ding
Darn Tootin'
You did loosen the track first didn't you?
saskattakman
you can also try to pull the case by hand while tapping the end of the shaft with a rubber hammer....tap the top and bottom shafts while putting pressure on the case....sometimes the bearings have a snug fit....
thanks everyone, finally got the case out, after growing an extra arm or two, lol Now the bearing on the speedo side is seized so tight on the shaft it bent my 2 jaw puller and still wont come off. Time to get a 3 jaw! Thanks again
sxray
did you loosen set screws on the bearing?
take a look
http://www.totallyamaha.net/forums/showthread.php?t=42684
Read post #8...good luck its easy...stand back & take a look at it again, you'll get it...cheersSRX44 said:In the middle of changing track and following instructions here. I cant remove the chaincase, do I need to remove entire parking brake assy and is there a trick to it. Does the rotor come with the case?
