Viper crank ???
yes, it will fit and run with it, just make sure its a 2000-02 srx crank for the viper cases
any gains or losses from doing this. i would assume that rotating weight would be a down fall, how much is the question. but also does using the srx crank have any advantage.
they will make the same power, this was done years back and dyno'd and the engine didnt make any more power either way.
