Who sells the Viper 780
How about
Have you tried Hauck or Simons. I would think they have them readily available.
Mmadmatt
alot nicer to just o-ring the cylinders and do away with those stupid headgaskets.
How is that done with the mega power heads? What about the space the gasket requires to get the correct squish. I'm now at .048 squish with three layers.
easy mac...... the heads work with o-rings as well as a gasket, you could bolt those right on a srx as well. I o-ring the cylinder tops and use srx o-rings, I would just simply need to cut .010"-.011" out of your squishband. Simple lathe work on domes, the cylinders I do on the cnc machine, after this its nice then you dont have all that mumbo jumbo and if you need to can take off heads and dont have to worry about gaskets, hi tack spray, etc.
Joe,
You’re a real barrel of laughs while my VIPER is apart. Joe is sure I can't beat him when my Viper is not ready. I cant beleive how early this winter has started. Anyway thanks Mr. Viper but I don't think the cost of machining both the heads and cylinders plus shipping warrent the convenience. Who knows maybe next year I take it apart every year just to take a look.
well youve already spent half of the cost on a gasket, next gasket and youll be there, but hey its your $$ spend it as you will, to each his own I guess.
