2000 SRX 700 clutch
MToutdoorsman
Alaska
I just picked up a 2000 SRX 700 with over 6000 miles on it and needing clutch work. Just wondering if anyone could recommend an aftermarket clutch or if I'd be better off getting the stock clutch rebuilt. This is the first "modern" sled I've owned since my prior machine was a 1975 John Deere 300 that worked real well for riding in eastern MT. Any ideas of common problems or trouble areas with the SRX would also be very helpful. http://www.totallyamaha.net/forums/:letitsnow
Letitsnow
I would just pull both clutches and inspect them. Replace any parts that look worn. I agree with SRX7, the stock clutch will work just fine. Do a search on here, there are some really good clutch set-ups on here using all stock parts.
Yeah, it's definitely a big difference from what I did have. Thanks for the input. I'll see what I can find for clutch combos on here. It's snowing a little bit every day so I'm just anxious to get the clutch fixed and start riding.
