Manuka
- Jan 27, 2005
I struggled with this last season and wanted to get back into here over the holiday break.
The sled would not fire a constant spark. It would spark at the very first turn of the key but none after. Turn the key back of and it would again fire once. There would be no spark after that first spark at the turn of the key.
My brother has the same exact sled. I swapped parts one by one on the sled to try and problem solve from the ignition to the plug wires and also bypassed the TORS, Nothing worked.
Not sure what to do or why this would even happen. It happened earlier in the season than magically fixed itself. The last time it happened was when I began to swap parts from the working sled. Since then it has sat.
Any thoughts?
Thanks in advance.
Any thoughts?
Thanks in advance.
sounds like a bad cdi or a wire rub through under the motor. i would unplug and fish out the harness to check fro rubthrough and repair as nessasary 1st. then you are into ohm measurements on the stator and cdi.
