vmax bearing question
mb-steve
Hubertus, WI
Can any of you Yamaha guys tell me if the PTO side crank bearings from a 96 vmax 600 will fit a 94 vmax 600. I already looked at the Yamaha micro fiche and see the part #s are different on the PTO side. However I can not believe they changed the crank machining between 94 & 96. So what I need is the 96 Koyo bearing numbers, not a Yamaha part number or 96 vmax bearing measurements (ID,OD, & width). Hoping somebody has this info from doing a rebuild as Yamaha won't give you that info.
Thanks,
Steve
