Peak Performance Heads
Coles_55
Eagle, WI
Looking to buy one, but would like to get as much information on them as possible. So I am looking to you guys for help, I tried to find their website but no luck. So any info would be great!
I put one on my sled a couple of years ago and havent rode it yet to know. I did notice the difference in the way the power hit when I took it for a ride across the yard. Think of it this way anytime that you add compression you will make more horsepower, and along with the HP comes heat, so you may end up adding a bigger cooler to help keep the light off.
Hey Coles can you do me a favor and take a picture of your rear cooler? and post it here. Thanks, T
Similar to shaved heads. Usually the combustion chamber is machined to a smaller cc size, thus raising the compression.
By shaving the heads you actually make the squish area tighter to the piston possibly causing detonation by removing to much material and making the squish band to tight.
just be careful on what heads to purchase..ask the salesman what fuel you are to use with the head that you would be purchasing.this is usually a problem with people that buy aftermarket cylinder heads, not knowing that a good quality pump gas or race fuel needs to be used....chip.
