SX700R RIDER
- Nov 13, 2004
I have A 2000 srx with the famous 8dn20s 4.5 rivits in both holes 48\40 advent edge helix www pirmary and green secondary at 70 wrap with good traction 8000 to 8100 hole shot climbing to 8200\8300 top end I weigh 230 with out gear is there A different rivit combo that would work better with my weight thanks
blueracer
helix
i believe with that set up you should have a 51/43 helix.
yamaholic22
Put a 3.6g rivet in the inner holes and you will be closer. Those rpms aren't too far off because you want to be in the meat of the torque out of the hole and power on the top end.
SX700R RIDER
- Nov 13, 2004
so the 3.6 would work thanks I was told 48\40 advant edge works A little better on 2000 and newer srx because they make a little more power and a lot of people with the 51/43 complain of a over rev. Thanks!
being you weigh a little more, have you tried simply wrapping the secondary to 80 twist? what kind of riding are you doing 90% of the time?
SX700R RIDER
- Nov 13, 2004
Mr. Viper-No I have not I will try that. Mostly very aggressive groomed trail riding. Thanks
