Oil out of the exhaust?
98700
Wishing for snow!
Hamilton, Ont
Hey guys,
I took off the PI pipes todoay to tighten all the exhaust flanges. But i took the pipes, and i held them up. There was oil coming ou of the pipe. I say between three pipe wthere was about 1/4-1/3 of a cup of oil. Why is this? This also happened a couple months ago when i took my stock pipes off.
Nik
Not to much. Maybe .5-1 KM. LOL, Just ripped her back and forth in the shop. Last year i only put MAX 100 KM on it everything was fine. Maybe just some built up oil in the engine?
daman said:
Just needs a good long rip, is it using allot of oil?
Not sure yet. I just put a litre of amsoil. And it didnt fill it all the way. But i will top it up and we'll see. But i need some hel pwith the sled idling now!!!! Look in my other thread please.
nik
Well guys, after a good 35-40 KM the oil consumption is pretty bad. I almost filled the oil tank (about 3/4 filled) And now after 35km I have about 3/8 of a tank. Oil is coming out of the exchaust still?
if you got oil cable free play set?, and it's not outa it seat in the cable housing?,your pump may have gone south..
well did you have the carb rack off this season for service...if so & you did it yourself...just go over all your cable adjustments, throttle end play, then your oil cable adjustment...common mistake when pulling the carb rack is stretching the the oil cable out of its seat & in effect forcing the oil pump to full open...or if you fogged your engine with the oil cable in the spring last year you didn't let it return to its seat at the adjuster block...
My man Daman has a good reply in another post you can fallow...cheers
Well looks like ya beat me again "D" :bump:
could also check and make sure the oil pump arm is returning to idle position,i thought i read earlier this season a member had just that problem.
Ok guys. I am going up now to check it out. I did have the carbs off this year, And again today. I will be heading out this weekend (Fri night to Tuesday) So I hope all is well! But I'll let you all know.
Nik!
