hd1450
Guys I just bought a 97 sx 1900 miles on it . It has a hauck roller secondary, green spring and 8ab-01 weights small rivet in the tip and a bigger one in the middle the spring is just black does this sound correct seems to run ok just a ?
What is it pulling for rpm,s at wide open throttle. Need to know that. if it,s 82-8500 rpm your good.
hd1450
sx
It is pulling 8200, If that set looks good to you turk thanks for your info your expertise is greatly appreciated
