Spark problem
buckeye-basser
Ohio
79 enticer 300 question
79 ET300C. Ok I fixed my carb problem and she ran awesome for a few days. Now I am getting good spark on one cylinder and the other it sparks once on the first pull and will not spark after that. Let it sit a while and the same thing. Do you guys think this is a bad plug or is the coil going. I wasnt thinking the coil because the other cylinder has plenty of spark and theres only one coil. Any suggestions would be appreceiated.
Even though there is only only one coil I believe it has 2 circuits. So I think it is possible that it would only spark on 1 plug.
As far as a bad plug.......try swapping plugs.
