Fuel problems
racer21
Willmar,Mn.56201
I have a 1997 700sx, it ran perfect until I put slp pipes on it and vforce 3 reeds, now whenever it's at idle or going slow speeds it starts to flood out until I give it some gas, then it goes like a rocket, as soon as I let off it starts to flood out again, so to trail ride it I just keep burping the throttle, It has 147.5 mains,50 pilots, air screw 11/2 turns out, I ride at 0-2000 ft. I think that the reeds are sucking too much fuel and the plugs are starting to foul causing the burble. Any suggestions would help, If I have to take the reeds out I can, We only ride ditches so top end is not important!! Thank's, R.J.
