Power INC End Dumps!
1slo_MM
Duluth, MN
I have a set of end dumps that i bought last year, and well...... got into an accident :o| and all three pipes got bent none are crushed.
Anybody know where i can get them fixed/straightened??
Or how i could do it myself?
thanks
-dru
:letitsnow
one way i heard of doing it is to plug the ends one with an outlet to hook up to an air compressor. then u heat the dent up with a torch and then pump in some air sould pop right out.
take them an autobody shop and get them to use a pin pullers. Same thing happened to me a few years back except 2 of mine were completey close off. You need a guy that knows what he is doing because after the pin is attached, a oxy/acetylene torch needs to be used to heat to red hot. This is the point were they should pull on the pin. I got mine straightened to about 98% of what they were before I smashed them up. Works well if the auto body guy knows his stuff.
I would think all autobody shops have pin pullers.
Good Luck.
That's what i thought, but didn't want to just assume. Why then do so many people swear by their exhaust for the 700 triples if they're not even IN BUSINESS any more?? Just curious. I've got CPR's on my 700 and would recommend them to almost anybody, but then again that is JUST my humble opinion
They recomend them because they where and still are some of the best power increase pipes. Just because they quit making sled pipes, still in business yet today, doesn't mean they pipes that where out will stop working. Maxdlx
