Can anyone give me some ideas on what to check on my SX700? It backfires when its warm when I start it. It only backfires once as soon as I pull the starter rope. It also only does it in warmer weather.
Thanks in advance
Thanks in advance
tedgoesfast
rich condition mine was doing this i had to replace needles valves when it shut of it would leak gas in the mag side if it sat to long it would flood itself
Have you clean your carbs!!!
Dnrtheil
My '02 SX600R does the same thing, unless I let it idle for a few seconds before I shut it off.
D
D
tyl4r
mine does it too, did it last night at the gas station and im pretty sure everyone getting gas sh*t themselves hahaha. i let mine idle down for a few seconds or choke it so it idles down and then shut it off.
jwiedmayer
Too high of idle speed and or pilots are out of adjustment. Lean usually backfires when cold.
check your timing if carbs are clean. advanced timing can cause a backfire.
Newfoundlander
Mine used to do the same thind I dropped my pilots to 40 and that got rid of it
