anyone know what the stock size jets are on a vmax 600 with 38mm flatslides? i run at 800+ sealevel, (minnesota) i put the carbs on my exciter 570 and am running a psi pipe. was going to go up 2 sizes from stock , and i don't know if the carbs i got have stock jets or not.
Yama49601
Well for a 1996 600 with 38mm's it's 162.5 mains, 65 pilots and 1 1/2 turns for the fuel screws.
Have a look here:
http://www.totallyamaha.com/snowmobiles/AAATuning Chart/Specs.htm
That info can be found at the "TY Tech" link in the menu bar at the top of the page.
I'm going to run 155 mains on the same carbs and same pipe but on a phazer...Don't know if there is diference just my opinion, and my pilots are 42.5 if I'm not mistaken....Nick
What are you running for clutch...?
