MSRX Clutching
phazerguy
SE WI
Just got my first SRX-98 MSRX, still stock.
I got a heavy hitter clutch kit for it and was wondering if anyone else has run this, how did you set it up? Did it work? what primary spring did you run and what do you recommend for the secondary clutch, looking for agressive trail/race. any suggestions???
Where you located?What's the elvation.The elevation can affect you over 1000rpms depending how high you go.
What kind of track are you running?I have a good heavy hitter set up.I know turk personally had a few msrx 's.
You can clutch em very close to a regular 98. I never used hc,s in any of mine but ryan(pro 116) has & can get you close. Clutching is similar but they use smaller rollers which makes em easier to clutch.
