Jaysled
I have a 2000 Phazer. Last night while riding it starting hesitating and not idiling right. So I took the carbs off tonight removed all the jets cleaned them with carb cleaner and blew them out with an air compressor. I put everthing back together and after adjusting everything got it running.
The question I have is how do you adjust the oil pump setting? Also the choke cable seems to have play in it and is not holding in the lever tight to the body. The air screw adjustment says 1 turn out and I set it that way, however it seems to be running rich and the machine seems to not be as peppy as it normally is. The plugs are black and wet.
Any help would be awesome. Thanks
Jaysled
Jaysled
